查看: 392|回复: 9
Steering wheel is off more than the 1 to 2 inches for fed regulations.
 楼主| 发表于 2019-11-1 05:58:00 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[{\"url\":\"http://d2w8udw005hdju.cloudfront.net/video/151933/android_753336_1572558959009.mp4\"}]","link":"{}","pics":"[{\"description\":\"\",\"height\":1080.0,\"name\":\"\",\"url\":\"\",\"width\":1863.0}]","canComment":true}
发表于 2019-11-1 07:09:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"the vid would not play for me.  Are you saying it is off center as depicted in the screenshot?  That has no part. what the 1-2\" refers to is play in the wheel.  if you turn it from side to side it should not have more than that amount of play.","replyToPid":0}
发表于 2019-11-1 14:32:56 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"That's fine.  With the engine off if you wiggle the wheel it shouldn't turn more then 1-2 inches before having resistance (called wheel play).\n\nThe wheel not being straight with the tires isn't regulated and is somewhat common in all vehicles.  Either the truck needs a front end alignment or it had one and the steering wheel alignment with the wheels is now off."}
发表于 2019-11-1 07:21:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"U should definitely go to the shop and spend 100s to fix that ","replyToPid":0}
发表于 2019-11-1 08:30:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes that  needs to be fixed spend the money lol ","replyToPid":0}
发表于 2019-11-1 11:07:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Google steering lash","replyToPid":0}
发表于 2019-11-1 11:51:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Front end alignment. ","replyToPid":0}
 楼主| 发表于 2019-11-2 06:09:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"yeah and the video was supposed to include the steering tires as I stepped out of the truck it is like that as I drive it's a company truck I guess sooner or later it'll get fixed","replyToPid":0}
 楼主| 发表于 2019-11-2 06:12:15 来自手机 | 显示全部楼层
65688 发表于 2019-10-31 23:09:40 the vid would not play for me.  Are you saying it is off center as depicted in the screenshot?  That has no part. what the 1-2\" refers to is play in the wheel.  if you turn it from side to side it should not have more than that amount of play.
","text":"yeah it's turning to the right it shows straighten steering tires as I get out of the truck in the video but it won't play for me either and recorded and sent it in.","replyToPid":239320}
 楼主| 发表于 2019-11-2 06:13:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks for intell.","replyToPid":0}
GMT+8, 2026-3-21 04:39 , Processed in 0.113868 second(s), 24 queries .
