查看: 127|回复: 6
Had a fuel stop and saw this. Figured I'd give it a try. Anyone here use this brand ?
 楼主| 发表于 2019-10-31 23:34:51 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true}
发表于 2019-11-5 02:17:03 来自手机 | 显示全部楼层
435615 发表于 2019-11-04 14:09:51 It's not an element cleaning replacement. It assist with the cleaning/removal. To be perfectly honest. Cardboard placed over the windows is the lazy/easy way to keep winter elements off of the windows. If you're talking quick easy, old school, no money needed remedy.
","text":"I use 91% alcohol 😎👍","replyToPid":242013}
发表于 2019-11-1 02:15:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not yet but sticking around for replies","replyToPid":0}
发表于 2019-11-1 13:24:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't waste my money on that, I do it old school solution without the scraper, I never have an ice buildup issue \nit only costs me $2 every winter","replyToPid":0}
 楼主| 发表于 2019-11-4 22:05:40 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Four bucks on this brand cut more than half the time cleaning windows. Also kept door key entry from freezing. I found a few other uses for this. All and all worked out good for me."}
 楼主| 发表于 2019-11-4 22:09:51 来自手机 | 显示全部楼层
I don't waste my money on that, I do it old school solution without the scraper, I never have an ice buildup issue it only costs me $2 every winter
{"replyToPid":239609,"replyTo":"
624525 发表于 2019-11-01 05:24:09 I don't waste my money on that, I do it old school solution without the scraper, I never have an ice buildup issue \nit only costs me $2 every winter
","text":"It's not an element cleaning replacement. It assist with the cleaning/removal. To be perfectly honest. Cardboard placed over the windows is the lazy/easy way to keep winter elements off of the windows. If you're talking quick easy, old school, no money needed remedy."}
 楼主| 发表于 2019-11-6 05:11:04 来自手机 | 显示全部楼层
624525 发表于 2019-11-04 18:17:03 I use 91% alcohol 😎👍
","text":"Use that in airline's during the winter.","replyToPid":242195}
GMT+8, 2026-2-12 11:14 , Processed in 0.075776 second(s), 24 queries .
