查看: 259|回复: 0
this is a 1999 international 9400i eagle
 楼主| 发表于 2019-10-31 22:41:00 来自手机 | 显示全部楼层 |阅读模式
Hide Access Link: https://prd-forum-api.truckerpath.com/v5/direct_link/?actionCode=AccessTruckAndJobAction&pk=9f276de016e22433564&token=02328162c43126fb49da032a6aef67e0
mileageV2: 00
horsePowerV2: 575
engineBrakeV2: 00
engineOverhaulV2: 00
turboV2: 00
transmissionRebuiltV2: 00
numberofSpeedV2: 10 Spd
overdriveV2: 00
differentialLockV2: 00
numberofRearAxlesV2: Tandem
grossVehicleWeightV2: 00
frontAxleWeightV2: 00
rearAxleWeightV2: 00
liftAxleV2: 00
superSinglesV2: 00
customPaintV2: 00
customChromeV2: 00
customFinishV2: 00
customExteriorV2: 00
aCV2: 00
powerLocksV2: 00
sleeperV2: 00
customSleeperV2: 00
navigationV2: 00
customSeatsV2: 00
metalAccentsV2: 00
woodgrainTrimV2: 00
customInteriorV2: 00
cabinetsV2: 00
convectionOvenV2: 00
deskV2: 00
dinetteV2: 00
microwaveV2: 00
refrigeratorV2: 00
showerV2: 00
sinkV2: 00
sofaV2: 00
stoveV2: 00
tVV2: 00
toiletV2: 00
washerDryerV2: 00
woodFloorV2: 00
aPUV2: 00
gliderKitV2: 00
headcheRackV2: 00
wetKitV2: 00
forkliftPackageV2: 00
includesForkliftV2: 00
fuelCapacityV2: 00
liftEndGateV2: 00
categoryOldV2: 2.37
categoryV2: Versatile Hauler Trucks
driversideV2: 2
zipcodeV2: 54966
cityV2: Plainfield
stateV2: WI
condV2: Used
emailV2: jamiescott12344@gmail.com
makemodelV2: INTERNATIONAL 9400i
phonenoV2: 7152042225
priceV2: 56500
latitudeV2: 44.21
longitudeV2: -89.49
modelyearV2: 1999
dualBreathersV2: 00
dualExhaustV2: 00
duallyV2: 00
heatedMirrorsV2: 00
tiltTelescopeV2: 00
cruiseControlV2: 00
powerSteeringV2: 00
insulatedV2: 00
{"text":"This truck has Detroit 60 12.7! has been in frame overhaul 65000 miles on it and new everything pretty much have recipes for all work done! hets 7 to 8 loaded at 80000 and 8to 10 empty depending which way the wind blowing!\n\nTrailer is a spread 48 2007 insulated. Had new plate put on 2 years ago in very good shap as showen!\n\nim asking 56500 for combination and will not split the two up!","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2160.0,\"name\":\"\",\"url\":\"\",\"width\":2160.0},{\"description\":\"\",\"height\":2160.0,\"name\":\"\",\"url\":\"\",\"width\":2160.0},{\"description\":\"\",\"height\":2160.0,\"name\":\"\",\"url\":\"\",\"width\":2160.0},{\"description\":\"\",\"height\":2160.0,\"name\":\"\",\"url\":\"\",\"width\":2160.0},{\"description\":\"\",\"height\":2160.0,\"name\":\"\",\"url\":\"\",\"width\":2160.0},{\"description\":\"\",\"height\":2160.0,\"name\":\"\",\"url\":\"\",\"width\":2160.0},{\"description\":\"\",\"height\":1134.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0}]","canComment":true}
GMT+8, 2026-4-2 16:55 , Processed in 0.068909 second(s), 25 queries .
