查看: 242|回复: 17
j
 楼主| 发表于 2019-10-31 11:14:03 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-10-31 12:16:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"And a different line of work.","replyToPid":0}
发表于 2019-10-31 12:16:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"You should consider rehab.","replyToPid":0}
发表于 2019-11-1 01:10:58 来自手机 | 显示全部楼层
280160 发表于 2019-10-31 14:12:41 only exception to this is using the truck for personal reasons while on hometime.\n\nie, you can drive the cab to a store while on hometime, buy liquor, and bring it back home.
","text":"Does it actually say that in the FMCSR? I’ve never heard that. ","replyToPid":238983}
发表于 2019-11-1 03:23:17 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"fmcsa interpretations website:\nhttps://www.fmcsa.dot.gov/regulations/title49/section/392.5\n\n\"Question 3: Does the prohibition against carrying alcoholic beverages in §392.5 apply to a driver who uses a company vehicle, for personal reasons, while off-duty?\nGuidance: No. For example, an owner-operator using his/her own vehicle in an off-duty status, or a driver using a company truck or tractor for transportation to a motel, restaurant, or home, would normally be outside the scope of this section.\""}
发表于 2019-10-31 12:50:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Cmon man, super dumb question. ","replyToPid":0}
发表于 2019-10-31 12:33:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"absolutely NOT!","replyToPid":0}
发表于 2019-10-31 11:19:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"can't keep it in the tractor","replyToPid":0}
 楼主| 发表于 2019-10-31 11:40:09 来自手机 | 显示全部楼层
796016 发表于 2019-10-31 03:19:48 can't keep it in the tractor
","text":"thanks but what about keeping in the trailer","replyToPid":238821}
发表于 2019-10-31 12:34:30 来自手机 | 显示全部楼层
222682 发表于 2019-10-31 03:40:09 thanks but what about keeping in the trailer
","text":"yes...if you have a BOL! other than that...nope!","replyToPid":238824}
发表于 2019-10-31 15:18:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Can’t have alcohol in the cab at all unless it’s part of the load that won’t fit on the trailer and paperwork reflects that. And it can’t be opened obviously. ","replyToPid":0}
发表于 2019-10-31 22:12:41 来自手机 | 显示全部楼层
{"replyToPid":238898,"replyTo":"
497499 发表于 2019-10-31 07:18:12 Can’t have alcohol in the cab at all unless it’s part of the load that won’t fit on the trailer and paperwork reflects that. And it can’t be opened obviously.
","text":"only exception to this is using the truck for personal reasons while on hometime.\n\nie, you can drive the cab to a store while on hometime, buy liquor, and bring it back home."}
GMT+8, 2026-2-11 10:49 , Processed in 0.081244 second(s), 24 queries .
