查看: 361|回复: 18
can i drink liquor in my truck ???
 楼主| 发表于 2019-10-31 01:17:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hey all, what is the law regarding drinking beer/liquor when taking 10 or 34 off ? \n","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-31 02:57:44 来自手机 | 显示全部楼层
497499 发表于 2019-10-30 18:16:10 No, it’s illegal to have open alcohol in a CMV.
","text":"It’s ok as long as it is on the manifest...","replyToPid":238520}
发表于 2019-10-31 02:16:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"No, it’s illegal to have open alcohol in a CMV. ","replyToPid":0}
发表于 2019-10-31 02:28:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"i'm under the impression that it's technically illegal to be under the influence at all while on a truck.. being  in the truck ,with the keys ,means you are in control of the vehicle...","replyToPid":0}
发表于 2019-10-31 12:43:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"no you cannot consume alcohol in your  truck nor can you have it in your truck even if it's still sealed.","replyToPid":0}
发表于 2019-10-31 02:59:47 来自手机 | 显示全部楼层
133538 发表于 2019-10-30 18:57:44 It’s ok as long as it is on the manifest...
","text":"Open though? ","replyToPid":238532}
发表于 2019-10-31 22:41:02 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I believe the FMCSA now states you must have 6 hours after drinking before you can drive.  There are no rules that say you can't drink on a 10 or 34, you just can't have alcohol IN the truck.  So could buy and drink before getting in, or drink at a local bar.  Your company may have it's own stricter rules though.\n\nKeep in mind that while it is legal to sleep in your truck while drunk, a cop can still try to charge you with a dui if the keys are in the ignition or in your pocket while you are in the truck.  They've done it with car drivers claiming it was intent to drive drunk.\n\nIn accordance with the FMCSA, you also can't legally be on duty if there is ANY alcohol in your system so be mindful of how much you drink.  If a dot officer finds ANY trace of alcohol in your system  you can be put out of service for 10 hours.  But it wont be a DUI unless you are over the legal limit."}
发表于 2019-10-31 03:17:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you like your job and don’t want to do anything illegal don’t have any alcohol with you","replyToPid":0}
发表于 2019-10-31 03:37:03 来自手机 | 显示全部楼层
{"replyTo":"","text":" Just make sure it’s in a cold thermal keeps the beer cold for when ur feeling thirsty ","replyToPid":0}
发表于 2019-10-31 03:03:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Probably not.  But if it is on the manifest and you opened it? Then theft is also a part of the conversation..","replyToPid":238533}
发表于 2019-10-31 02:06:33 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"if you are doing a 34 and want to drink, your best bet is to get a motel room  and drink away from the truck and not within 10 hrs of going back to work."}
发表于 2019-10-31 01:40:06 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Can do"}
发表于 2019-10-31 01:59:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"I do know that if you are on a 34, alcohol can be consumed within the first 24 hours, but not on the truck.","replyToPid":0}
发表于 2019-10-31 03:07:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"8 hours between the bottle and the throttle!!!!","replyToPid":0}
GMT+8, 2026-2-11 10:49 , Processed in 0.091686 second(s), 24 queries .
