查看: 83|回复: 8
watch out for high speed wind on I10 near Blythe California
 楼主| 发表于 2019-10-30 23:08:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"specially if you are empty dry van. just saw amazon trailer flip. I myself can barely move. had to stop . ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-31 06:56:01 来自手机 | 显示全部楼层
747109 发表于 2019-10-30 16:13:09 hmmmm, I am fully loaded so made it  through at low speed. but it keep pushing my tractor away. wasn't very pleasant.
","text":"👀😳😳😳😳😳🌬🚛💨","replyToPid":238455}
 楼主| 发表于 2019-10-31 00:13:09 来自手机 | 显示全部楼层
497499 发表于 2019-10-30 15:47:17 Santa Clarita winds got up to 55mph. Last night was bad in Jurupa Valley
","text":"hmmmm, I am fully loaded so made it  through at low speed. but it keep pushing my tractor away. wasn't very pleasant.","replyToPid":238436}
 楼主| 发表于 2019-10-31 06:12:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks !😊","replyToPid":238595}
发表于 2019-10-30 23:47:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Santa Clarita winds got up to 55mph. Last night was bad in Jurupa Valley","replyToPid":0}
发表于 2019-10-31 02:52:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good luck, and keep your Greasy side down!","replyToPid":0}
发表于 2019-10-31 04:30:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"becarful drive safe🙏","replyToPid":0}
发表于 2019-10-31 10:53:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Turned out to be pretty bad today by the Cajon Pass on 15... I believe that's right by the weight station before the Bypass. \n4+ trucks flipped over today","replyToPid":0}
 楼主| 发表于 2019-10-31 19:37:28 来自手机 | 显示全部楼层
553636 发表于 2019-10-31 02:53:54 Turned out to be pretty bad today by the Cajon Pass on 15... I believe that's right by the weight station before the Bypass. \n4+ trucks flipped over today
","text":"I wouldn't be surprised , it was horrible . I did saw amazon trailer flipped on westbound.","replyToPid":238816}
GMT+8, 2026-2-13 16:27 , Processed in 0.062041 second(s), 24 queries .
