查看: 136|回复: 4
The fridge in our truck died. Will find replacement asap! Can you guys suggest whats a better fridge to buy?
 楼主| 发表于 2019-10-29 09:19:22 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":960.0,\"name\":\"\",\"url\":\"\",\"width\":714.0}]","canComment":true}
发表于 2019-10-29 10:21:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get one from walmart its cheap and good","replyToPid":0}
发表于 2019-10-29 11:53:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dometec or Yeti.","replyToPid":0}
发表于 2019-10-29 11:39:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Haier","replyToPid":0}
发表于 2019-10-29 20:42:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"What type of fridge was in your truck? Mine was a nova Kool and I just got it going with help from the factory guys. Very helpful. I can give you the number on message on here. Turned out to be a simple repair. They said it most often is simple to fix. They will walk you through the diagnostic process. Very helpful. ","replyToPid":0}
GMT+8, 2026-4-16 20:48 , Processed in 0.089278 second(s), 25 queries .
