查看: 326|回复: 12
Only swift is eligible to perform such maneuver. LOL kidding.
 楼主| 发表于 2019-10-29 09:14:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":947.0,\"name\":\"\",\"url\":\"\",\"width\":745.0}]","canComment":true}
发表于 2019-10-29 20:39:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why do these drivers think you need to even need to touch the brakes to go downhill?  Downshift and ride the jakes, regardless of the \"No engine brakes\" signs in some areas...  A noise ordinance ticket is much cheaper than a tow truck, ramp ticket, and repairs.","replyToPid":0}
发表于 2019-10-29 10:31:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"A lot of the ones up here are filled deep pits of 3/4 inch round gravel. \n\nMakes ya sink to the axels","replyToPid":0}
发表于 2019-10-31 07:06:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ah, that eco thing?   Illegal to do on a standard, but acceptable if it's an automatic.","replyToPid":0}
发表于 2019-10-30 21:03:10 来自手机 | 显示全部楼层
786444 发表于 2019-10-30 00:22:47 I don't see a flake of snow or other indications of ice on the road, mountain, or trees in that meme.  Perhaps the driver should have chained up or just wait for the salt shakers and ice scrapers to do their job before sliding off the perfectly dry road.\n\nVolvo's kicking into neutral sounds like a recall.  Got more info on that besides 235 Volvo trucks having a 5 amp fuse where a 30 amp should be?\n\nhttps://static.nhtsa.gov/odi/rcl/2019/RCLRPT-19V509-2811.PDF
","text":"The neutral thing is how the new auto transmissions are programmed.  I just started with ABF after a decade in the oilfield. All of their trucks from 2015 freightliners to 2017 and 2019 Mack’s and 2018 Kenworths drop into neutral when ever they are off the throttle when the cruise is on","replyToPid":237859}
发表于 2019-10-29 23:27:25 来自手机 | 显示全部楼层
843235 发表于 2019-10-29 05:38:49 looks like the one on I-80 in Oregon
","text":"Where does I-80 run through Oregon?!  Certainly you mean I-84...","replyToPid":237324}
发表于 2019-10-29 11:05:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"That almost looks like one of the ramps on westbound I-70 just west of Eisenhower tunnel","replyToPid":0}
发表于 2019-10-29 13:38:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"looks like the one on I-80 in Oregon","replyToPid":0}
发表于 2019-10-29 10:20:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Actually not that hard to believe 🤔\nRunaways are most  of times brakes related , \nSo if brakes don’t hold u going in forward , they can’t hold u in reverse ??\nSo that’s one of the options to stop rig before gaining backward momentum ","replyToPid":0}
发表于 2019-10-29 22:16:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"The new Volvo automatic kick into neutral and jaking on a icy curved road is ill advised. \n\nA lot of these automatics dont hold speed back like manuals ","replyToPid":0}
发表于 2019-10-30 07:40:44 来自手机 | 显示全部楼层
133538 发表于 2019-10-29 15:27:25 Where does I-80 run through Oregon?!  Certainly you mean I-84...
","text":"My bad..I certainly did mean I-84!!","replyToPid":237494}
发表于 2019-10-30 08:22:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't see a flake of snow or other indications of ice on the road, mountain, or trees in that meme.  Perhaps the driver should have chained up or just wait for the salt shakers and ice scrapers to do their job before sliding off the perfectly dry road.\n\nVolvo's kicking into neutral sounds like a recall.  Got more info on that besides 235 Volvo trucks having a 5 amp fuse where a 30 amp should be?\n\nhttps://static.nhtsa.gov/odi/rcl/2019/RCLRPT-19V509-2811.PDF","replyToPid":0}
GMT+8, 2026-2-13 18:15 , Processed in 0.079837 second(s), 24 queries .
