查看: 230|回复: 15
What is the best method to get 4 wheelers to quit tailgating you?
 楼主| 发表于 2019-10-29 07:16:31 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-10-29 07:56:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"I typically ignore them unless they have their high beams on, in which case I’ll slow down to a crawl forcing them to pass me. ","replyToPid":0}
回复 支持 7 反对 0
发表于 2019-10-29 07:35:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ride the shoulder so they catch rocks. \n\nSqueeze the spike. \n\nBuild a gravel bin on the back of your tractor fill with pea sized gravel and dump air suspension hit some bumps. \n\nOnly limit is your imagination ","replyToPid":0}
发表于 2019-10-29 20:45:28 来自手机 | 显示全部楼层
689986 发表于 2019-10-29 03:18:49 First grow a pair and then throw that göd dâmn engine brake on, drop 2 gears and let them mother fückers kiss your arse then after you get your pécker out your arse throw a bottle of pïss and that windshield as they drive off.
","text":"Such class. Wow ","replyToPid":237285}
发表于 2019-10-29 20:48:12 来自手机 | 显示全部楼层
","text":"Wow","replyToPid":237285}
发表于 2019-10-29 13:33:00 来自手机 | 显示全部楼层
","text":"whatever you do..don't do this.","replyToPid":237285}
发表于 2019-10-29 11:08:31 来自手机 | 显示全部楼层
843235 发表于 2019-10-29 00:32:56 I slow way down..I have got down below 20mph before they went around!
","text":"I do this too","replyToPid":237154}
发表于 2019-10-29 08:32:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"I slow way down..I have got down below 20mph before they went around!","replyToPid":0}
发表于 2019-10-29 07:53:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I just turn in my right turn signal so they think ima slow down","replyToPid":0}
发表于 2019-10-29 09:41:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"put your hazards on they'll go around","replyToPid":0}
发表于 2019-10-29 08:29:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Make a fake claymore and secure it to the ICC and not the sword....","replyToPid":0}
发表于 2019-10-29 09:08:34 来自手机 | 显示全部楼层
{"replyTo":"","text":" Nothing it’s there life not mines. ","replyToPid":0}
发表于 2019-10-29 12:27:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"it only costs pennies 😈","replyToPid":0}
GMT+8, 2026-2-11 09:04 , Processed in 0.125113 second(s), 24 queries .
