查看: 329|回复: 10
Any recommendation for mechanic's in El Paso??
 楼主| 发表于 2019-10-29 03:12:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"what a nightmare happened early morning... just hit a curve today and need two tires are rim two airbags and fixing of frame.thank you for your help in advance👍👍","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1092.0,\"name\":\"\",\"url\":\"\",\"width\":2304.0},{\"description\":\"\",\"height\":2280.0,\"name\":\"\",\"url\":\"\",\"width\":1080.0}]","canComment":true}
发表于 2019-10-29 10:38:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"guys he's asking recommendation.","replyToPid":0}
发表于 2019-10-29 09:35:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"That’s going to cost thousands dude","replyToPid":0}
发表于 2019-10-29 11:11:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"go back to trucking school.... best recommendation","replyToPid":0}
发表于 2019-10-29 09:40:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"holy sh!t is that a swift trailer? how do you not notice your about to hit something that big","replyToPid":0}
发表于 2019-10-29 14:15:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"And yaa forgot to tell you. When you go back make sure you keep the same speed otherwise it’s not gona work ","replyToPid":0}
发表于 2019-10-29 11:53:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"WOW, just WOW!","replyToPid":0}
 楼主| 发表于 2019-10-29 13:43:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks everyone's for wonderful feedback especially from Black Sheep.   NAME explains it all,don't change it suits your personality just perfect!!","replyToPid":0}
发表于 2019-10-29 14:02:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"What are your going to fix  this is salvage now ","replyToPid":0}
发表于 2019-10-29 14:05:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"yaiks! that's gonna cost you man!","replyToPid":0}
发表于 2019-10-29 14:07:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just go back the same way and hit the left side. It will straighten up a little. You will be fine ","replyToPid":0}
GMT+8, 2026-4-18 09:07 , Processed in 0.096316 second(s), 24 queries .
