查看: 210|回复: 11
SCALEHOUSE UPDATES
 楼主| 发表于 2019-10-29 02:12:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"I've been told a few things by other truckers, but can anyone tell me the facts about exactly what \"ACTIVELY MONITORED\" means? ","videos":"[]","link":"{}","pics":"[]","canComment":false}
 楼主| 发表于 2019-10-29 04:14:46 来自手机 | 显示全部楼层
If your that worried about it go around them or make sure your stuff is up to snuff alittle better it’s not that hard
{"replyToPid":236889,"replyTo":"
674413 发表于 2019-10-28 18:59:29 If your that worried about it go around them or make sure your stuff is up to snuff alittle better it’s not that hard
","text":"14 years on paper logs makes you a little bit leery. If I was a company slave on elogs I wouldn't gaf"}
发表于 2019-10-29 09:23:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"It mean what the fûck it says dûmbaśś, they actively monitoring, \n\nFor your remedial aśś they in the building watching the scale laughing and joking, the machines are beeping and when the at one truck that rides buy beeps red they pull him in or when they tell that last joke, and captain say let’s get to work they turn around and start pulling trucks in 🤬🤬🤬🤬","replyToPid":0}
发表于 2019-10-29 22:44:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well if you don’t know how to make them work by now and look good then you got problems been doing paper logs for over 20yrs and never have issues ","replyToPid":0}
发表于 2019-10-29 05:56:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Since \"Activity Monitored\" is below \"Closed\" I have been assuming that it's for Scale Houses that have highway speed \"Weigh in Motion\" on the interstate. some of which don't have an actual Scale to pull into. \nBut, I agree that a little definition would've been helpful.","replyToPid":0}
发表于 2019-10-29 02:59:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"If your that worried about it go around them or make sure your stuff is up to snuff alittle better it’s not that hard ","replyToPid":0}
 楼主| 发表于 2019-10-29 02:54:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"I know 7 or 8 that leave a state patrol car parked in the coop every day but nobody is there","replyToPid":236884}
发表于 2019-10-29 02:48:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"officer's sitting there","replyToPid":0}
 楼主| 发表于 2019-10-29 02:52:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Open or closed though?","replyToPid":236880}
发表于 2019-10-29 06:11:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you want to know what actively monitored means then next time you go through the tube look at all the cameras that are on every light post and every corner of the building and then understand that someone is watching those cameras all the time because if you're out of service and then they shut down the coop and go home and then you leave they're going to catch you that's what they're trying to tell you","replyToPid":0}
GMT+8, 2026-2-13 14:54 , Processed in 0.083281 second(s), 24 queries .
