查看: 143|回复: 9
I'm still curious
 楼主| 发表于 2019-10-26 05:24:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"On how you can have a fresh one beside a bad one. lol","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1138.0,\"name\":\"\",\"url\":\"\",\"width\":640.0}]","canComment":true}
发表于 2019-10-27 03:39:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"That can also be caused by mounting mismatched tire diameters. The tread on the smaller tire will be scrubbed off in a relatively short time.","replyToPid":0}
发表于 2019-10-27 00:26:08 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"obviously it's a retread you can tell because it blew the whole tread off and the straps is holding the Damaged fairing up. if you look you can see where the cap came off and bent up the brackets exactly what that is it's a retread recap. people try to be a little cheaper and buy that and put on their truck thinking they're saving money but when that tread comes off and destroys your truck you just spent more"}
发表于 2019-10-26 08:21:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Called being cheap","replyToPid":0}
发表于 2019-10-26 20:04:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"How you didnt know?","replyToPid":0}
发表于 2019-10-27 02:23:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"That’s what random roadside inspections are for. ","replyToPid":0}
发表于 2019-10-27 10:01:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Retread came off ","replyToPid":0}
发表于 2019-10-27 13:55:04 来自手机 | 显示全部楼层
760648 发表于 2019-10-26 19:39:18 That can also be caused by mounting mismatched tire diameters. The tread on the smaller tire will be scrubbed off in a relatively short time.
","text":"Learned that the the hard way recently had that happen mismatch tires ","replyToPid":235829}
发表于 2019-10-27 14:27:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤔🤔🤔🤔🤔","replyToPid":0}
发表于 2019-10-27 15:47:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"get a new one man!","replyToPid":0}
GMT+8, 2026-2-11 02:00 , Processed in 0.086637 second(s), 24 queries .
