查看: 322|回复: 30
SO WHEN IT SAYS TANDEMS AT 5TH HOLE IN CALIFORNIA , DOES THAT MEANS TENDEMS CAN BE AT ANYWHERE FROM 1ST TO 5TH HOLE ?
 楼主| 发表于 2019-10-26 02:38:05 来自手机 | 显示全部楼层 |阅读模式
{"text":"OR DOES IT MEAN 5 OR  5 PLUS ? ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-26 04:33:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hey! I'm earning cash just to drive without using my phone with OnMyWay! You can too by signing up at https://r.onmyway.com/YwcVSp4vT0","replyToPid":0}
回复 支持 0 反对 3
 楼主| 发表于 2019-10-27 00:42:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"And then truck driver gotta take sh$$ from everybody. They treat truck drivers like we are some low life uneducated POS. this is sad ! \nno respect for truck driver !","replyToPid":0}
发表于 2019-10-27 11:03:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"it means the front lock pin should be in the 5th hole back from the front.","replyToPid":0}
发表于 2019-10-26 11:31:10 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Best to measure that out. Most trailers now 3rd hole is the 40 foot mark for tandems\n\nAlso it’s 40 feet or less. "}
发表于 2019-10-26 04:18:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Anywhere from 1st to 5th","replyToPid":0}
发表于 2019-10-26 03:56:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"it means your in mexico","replyToPid":0}
 楼主| 发表于 2019-10-26 12:20:13 来自手机 | 显示全部楼层
542330 发表于 2019-10-26 03:31:10 Best to measure that out. Most trailers now 3rd hole is the 40 foot mark for tandems\n\nAlso it’s 40 feet or less.
","text":"I am 11640/31740/36420 in 5th hole .","replyToPid":235538}
发表于 2019-10-26 12:46:55 来自手机 | 显示全部楼层
{"replyToPid":235553,"replyTo":"
747109 发表于 2019-10-26 04:20:13 I am 11640/31740/36420 in 5th hole .
","text":"You need to get that reworked. \n\nHave had many loads reworked just because of that California bridge law. \n"}
发表于 2019-10-26 12:50:35 来自手机 | 显示全部楼层
","text":"Here is a website with a good explanation of it. \n\nhttps://www.donhummertrucking.com/blog/2016/11/14/learn-about-california-s-kpra-law","replyToPid":235553}
 楼主| 发表于 2019-10-27 00:37:54 来自手机 | 显示全部楼层
You need to get that reworked. Have had many loads reworked just because of that California bridge law.
{"replyToPid":235566,"replyTo":"
542330 发表于 2019-10-26 04:46:55 You need to get that reworked. \n\nHave had many loads reworked just because of that California bridge law. \n
","text":"been to shipper back 3 times 🤣 they readjust the load and I go 20 miles out to TA to get checked on scale still coming over weight on trailer axel . \nwent back 4th time they said they cant do nothing about it just take it the way it is , you should be ok since your gross is less than 80k . and then on top of it they called security on me saying you gotta leave with the load because we dont have enough parking for everybody."}
 楼主| 发表于 2019-10-27 00:40:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"I am on day 3 of doing this , haven't left shipper yet.  😆 I thought driving was the hard part in truck driving . but seems like dealing with shipper and consignee is whole diffrent level .","replyToPid":0}
GMT+8, 2026-2-13 13:03 , Processed in 0.077862 second(s), 24 queries .
