查看: 227|回复: 8
Toad's wild ride
 楼主| 发表于 2019-10-25 20:03:17 来自手机 | 显示全部楼层 |阅读模式
{"text":"Good morning.  I took one for the team so everyone behind me can keep rolling! it was a wild ride but I have a spill proof coffe mug. I'll catch up. ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1512.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0}]","canComment":true}
发表于 2019-10-25 21:58:54 来自手机
{"replyTo":"","text":"you may not of spilled your coffee.. but I bet you pooped your pants.","replyToPid":0}
支持 4 反对 0
发表于 2019-10-27 00:53:16 来自手机 | 显示全部楼层
That’s funny😂😂😂 If a proper pretrip is done right and you actually get out and use that tool called a tire gauge (it’s for checking air pressure in tires) also there is a mark on steer tires that actually shows you when to change your tires before they actually get wore out, that could of been prevented. I hope your an owner op. Enjoy that $400. Tire and $400 rim
{"replyToPid":235060,"replyTo":"
689986 发表于 2019-10-25 12:26:50 That’s funny😂😂😂 If a proper pretrip is done right and you actually get out and use that tool called a tire gauge (it’s for checking air pressure in tires) also there is a mark on steer tires that actually shows you when to change your tires before they actually get wore out, that could of been prevented. I hope your an owner op. Enjoy that $400. Tire and $400 rim
","text":"a super trucker that drives an international , now that's funny 😂😂🤣🤣😅"}
发表于 2019-10-25 23:29:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Could be a defective tire that a pretrip (even a thorough one) couldn't have caught. I had a new, properly inflated, 2 week old steer tire blow out on me 2 years ago. At least Southern Tire Mart honored their warranty and replaced my aluminum rim at no charge too.","replyToPid":0}
 楼主| 发表于 2019-10-26 23:56:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks Negative Nancy. Fyi I did pretrip less than 30 min prior. Nothing out of sorts. Not o/o like you super trucker.  curb your hate or Mother Karma will come for you. ☻🧟‍♀️⛟","replyToPid":0}
发表于 2023-3-27 13:33:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lot of guys freak out and slam on the brakes when a front tire goes...they usually end up in the ditch or flipped.  Good Save!","replyToPid":0}
发表于 2019-10-25 21:07:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"That’s fun ride when that happens ","replyToPid":0}
发表于 2019-10-25 21:54:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"even though it's a fun ride the hood is still there and your ok could've been worse","replyToPid":0}
发表于 2019-10-26 00:35:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"hey it's only flat on the........oh wait","replyToPid":0}
 楼主| 发表于 2019-10-26 23:58:39 来自手机 | 显示全部楼层
{"replyToPid":235107,"replyTo":"
452317 发表于 2019-10-25 13:58:54 This comment has been deleted
","text":"no lol.  Loma Prieta 7.2 quake hit when I was 16  in Santa Cruz and I stood on top of the steps holding onto the railing like a broc rider yelling yeehaw."}
GMT+8, 2026-4-17 04:45 , Processed in 0.106448 second(s), 25 queries .
