查看: 177|回复: 7
truck GPS vs truckerpath
 楼主| 发表于 2019-10-25 09:52:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"is it worth it To spend money on an expensive GPS for truck if i already use the navigation option from this app??? seems Like it work pretty Well since i use it.","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-25 23:25:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Trucker gps is better for several reasons\n\nNot using your data \n\nNot using phone while driving\n\nA trucker gps has low bridges weight limits length limits\n\nI tried to use the app 1 time and it had me go on a road with 60 foot length limit. ","replyToPid":0}
发表于 2019-10-26 02:33:26 来自手机 | 显示全部楼层
 楼主| 发表于 2019-10-25 22:15:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"the data usage is really low if You download the Maps of where You have To go. i have other apps that take way more data on a daily base. since im using truckerpath i never exeded my data plan and its been pretty acurate too.","replyToPid":0}
发表于 2019-10-26 01:32:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Keeping taking this app for a spin and let time tell you. ","replyToPid":0}
发表于 2019-10-26 02:10:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don’t recommend relying on your phone for navigation. When a phone call comes through it can distract and disrupt your directions, and constantly using GPS can destroy your device’s battery life. ","replyToPid":0}
发表于 2019-10-26 04:29:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"it does work well.\nalthough, it does tend to send you off some roads you probably shouldn't chance. and it works on speed limit not governed or hill delays for eta.","replyToPid":0}
发表于 2019-10-28 08:29:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"I love my Garmin GPS, but it doesn't show closed roads and construction changes. I always back up my Trucker GPS with Google Maps. Google Maps is the most valuable app. I can even get a satellite image of destination. I haven't had very good results with Trucker Path.","replyToPid":0}
GMT+8, 2026-2-13 14:55 , Processed in 0.070939 second(s), 24 queries .
