查看: 98|回复: 6
I hate delivering to Grocery DCs.
 楼主| 发表于 2019-10-25 05:01:39 来自手机 | 显示全部楼层 |阅读模式
{"text":"You get there on time for your appointment, then you wait in the staging area for an hour or two. \n\nThen a lumper charges a fortune to unload THEIR stuff. I understand it's all part of trucking and after years I should be use to it.\n","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-25 21:50:59 来自手机 | 显示全部楼层
836417 发表于 2019-10-25 13:13:36 kroger is the worst i seen so far
","text":"Kroger in Delaware, Ohio is the worst. That place is a s×÷= hole.","replyToPid":235071}
发表于 2019-10-25 22:13:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don't you dare breakdown and be late, they'll rake you over the coals.","replyToPid":0}
发表于 2019-10-25 21:48:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"I found if you tell them that your going to go get some rest while you wait they usually try to get you in faster because they dont what you rested","replyToPid":0}
发表于 2019-10-26 18:16:02 来自手机 | 显示全部楼层
669771 发表于 2019-10-25 18:32:07 Costco is the absolute best. In and out in under an hour. Super Valu can be pretty good too. Especially the one in Hopkins Mn. \nAldi is terrible \n\nGrocery DCs should pull freight off, stamp the bills “subject to count” and send the driver on their way. In and out in an hour. Instead they count every freaking case.
","text":"I agree with the Hopkins one.  Been to both sides.  Grocery and cold.  Although I think cold side is a bit better but grocery side does have the Pepsi soda machine with Coke in it.  And a place to sit while waiting to find the head lumper..... (¬‿¬)","replyToPid":235229}
发表于 2019-10-26 02:32:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Costco is the absolute best. In and out in under an hour. Super Valu can be pretty good too. Especially the one in Hopkins Mn. \nAldi is terrible \n\nGrocery DCs should pull freight off, stamp the bills “subject to count” and send the driver on their way. In and out in an hour. Instead they count every freaking case. ","replyToPid":0}
发表于 2019-11-1 14:06:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"you're complaining about waiting an hour or two? wow, the struggle is real in Atlanta today. just did eight and a half hours waiting to get loaded. now I'll start my day.","replyToPid":0}
GMT+8, 2026-2-11 15:44 , Processed in 0.057876 second(s), 24 queries .
