查看: 360|回复: 7
Heard a new driver today complaining that he doesn’t like automatic transmissions.
 楼主| 发表于 2019-10-25 04:56:31 来自手机 | 显示全部楼层 |阅读模式
{"text":"I asked him have you ever drove with your right heal on the break your right toes on the throttle ...your left leg on the clutch and using it to hold the steering wheel....your left elbow turning the blinker on and off ....reaching your left hand through the steering wheel to shift the main transmission ...your right hand shifting the browny .... all while changing the a.m. radio station. That was normal Trucking coming up to a stop sign making a turn on a small incline ....That was Trucking back in the 70s back when you wouldn’t even think of wearing flip-flops, back when you really had to be talented to drive a truck.... By the way I don’t like automatics either.\n","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-25 07:50:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"If he knows how to use manual it's good in case he got a truck with manual. Wearing flipflops and driving automatic Volvo doesn't make you bad driver as long nose Pete doesn't make you professional. Doing your job properly and helping fellow drivers does! Mind your own businesses and help each other! Peace...","replyToPid":0}
回复 支持 8 反对 2
发表于 2019-10-25 08:56:14 来自手机 | 显示全部楼层
572825 发表于 2019-10-24 23:50:20 If he knows how to use manual it's good in case he got a truck with manual. Wearing flipflops and driving automatic Volvo doesn't make you bad driver as long nose Pete doesn't make you professional. Doing your job properly and helping fellow drivers does! Mind your own businesses and help each other! Peace...
","text":"word of the day ! you need to preach 🙌","replyToPid":234746}
发表于 2019-10-25 07:03:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don’t like them either. But sadly most companies are going to them.","replyToPid":0}
发表于 2019-10-25 18:40:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"wearing flip flops does make you a bad driver...","replyToPid":0}
发表于 2019-10-25 07:24:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"powerstering turning if you didn't clutch well.","replyToPid":0}
发表于 2019-10-25 07:29:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"question? downtime on automatic or straight shift? downtime on electronics or old school fuses?  how do you stop moving,  old school or  today's new  toys?","replyToPid":0}
发表于 2019-10-26 05:04:27 来自手机 | 显示全部楼层
689986 发表于 2019-10-25 12:39:45 Wearing flip flops, having a diaper full of chit on your head, wearing shorts, wearing sweat pants, or smelling like a curry whòre is the new drivers I hate. And I love automatic transmissions. I’ve shifted enough gears ⚙️ and been in slow traffic. I pass you mother trucking gear jammers and keep up with you cattle haulers. I will keep my auto and you can guzzle that diesel with you 16 speed shifting arse. Any thing below 16 don’t bïtch about automatics. You dipchits don’t even shift out. You been skipping gears like a loose bítch.
","text":"🤣","replyToPid":235064}
GMT+8, 2026-4-18 21:26 , Processed in 3.047093 second(s), 24 queries .
