查看: 319|回复: 2
Thanks alot a holes....pulled in to get fuel and these clowns decided to spend the night there...
 楼主| 发表于 2019-10-25 04:50:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"I had to.back up onto the highway traffic on both sides while these lovebirds slept..... on I35 by Ottawa Ks....\n","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":720.0,\"name\":\"\",\"url\":\"\",\"width\":960.0}]","canComment":true}
发表于 2019-10-25 09:33:40 来自手机 | 显示全部楼层
815831 发表于 2019-10-25 01:25:31 That's when you nose in between them and lay on your air horns! That's what I'd do.
","text":"same, one, if not both will eventually move.","replyToPid":234820}
发表于 2019-10-25 09:25:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"That's when you nose in between them and lay on your air horns! That's what I'd do.","replyToPid":0}
GMT+8, 2026-4-18 23:36 , Processed in 0.522521 second(s), 24 queries .
