查看: 220|回复: 11
Service provider question,,,, what phone carriers you guys are all with?
 楼主| 发表于 2019-10-25 02:55:19 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-10-25 03:08:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Straight Talk, and ATT&T go phone for us, pretty much have service everywhere, and the few places one don't have signal the other one does.","replyToPid":0}
发表于 2019-10-25 03:08:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"been with Verizon for over a decade, just switched to ATT last month, BEST DECISION EVER. 10x faster data speeds  and better coverage.","replyToPid":0}
发表于 2019-10-25 03:17:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"AT&T for my main phone and a Verizon for AT&Ts dead zones","replyToPid":0}
发表于 2019-10-25 04:05:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"verizon is the only way if you are willing to pay high dollars . otherwise ATT is next level down . \nI would not touch any other company being a truck driver . \nspeed doesn't matter as much since both of them are very close . if you iphone you will get little faster data  speed on att since they are programmed best for att network. if you have any other phone all speed is pretty much same on 4g LTE . 5G coverage is not available yet for highways and country areas , and probably not be available till next 5 years like 4g. so dont get into a company by looking at their 5G sign . it's all useless right now unless you will be in 5G coverage range (which is very small currently)","replyToPid":0}
发表于 2019-10-25 04:06:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Verizon","replyToPid":0}
发表于 2019-10-25 04:37:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"AT&T’s network via Crickett for main phone (LTE) and tablet (3g) since their billing and plans are comparable but simpler, Verizon for ELD, and T-mobile for when I’m in Utah or those small rural pockets where they’re the only game in town. I use my own custom router solution so everything is always connected. ","replyToPid":0}
发表于 2019-10-25 04:42:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes at&t is the best coverage I've found.. pretty much every where and most times my data speeds are 40 mbs or higher.","replyToPid":0}
发表于 2019-10-25 05:24:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"i have Sprint it comes with free Hulu I pay about $65/mo.","replyToPid":0}
发表于 2019-10-25 05:48:42 来自手机 | 显示全部楼层
GMT+8, 2026-4-17 00:53 , Processed in 0.151891 second(s), 23 queries .
