查看: 271|回复: 13
And he is still driving. Yes, he is.
 楼主| 发表于 2019-10-25 01:38:58 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":853.0,\"name\":\"\",\"url\":\"\",\"width\":640.0}]","canComment":true}
发表于 2019-10-25 14:55:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't know if y'all can see but he has the axle chained up most likely cuz he knows it's cheaper than a call out","replyToPid":0}
发表于 2019-10-25 14:45:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"(At least w/ 18, u can \"limp\" to a safe spot down the road.)","replyToPid":0}
发表于 2019-10-25 04:32:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Wow","replyToPid":0}
发表于 2019-10-25 08:07:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"well he's gonna need a rim as well SMH","replyToPid":0}
发表于 2019-10-25 13:52:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Is it possible to not feel that behind you? I somehow doubt it. ","replyToPid":0}
发表于 2019-10-25 14:00:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"oh wow be safe out there you guya","replyToPid":0}
发表于 2019-10-25 21:36:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"wow he should be fired","replyToPid":0}
发表于 2019-10-25 21:55:06 来自手机 | 显示全部楼层
689986 发表于 2019-10-25 05:59:28 That’s why I never will use those new single tires. I will keep my 18 wheels and tires
","text":"I never did like the \"Super single tire\" I'm like you, rather have 18.","replyToPid":234982}
发表于 2019-10-26 01:52:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"What the OP fail to\nMention is it’s a TA two exits up. \n\nWhy wait 4 hours on the side of the road when you can drive 30 mins. ","replyToPid":0}
GMT+8, 2026-2-13 09:36 , Processed in 0.107142 second(s), 24 queries .
