查看: 509|回复: 48
What do I do if I run out of ours during unloading and the property won't allow me to park there?
 楼主| 发表于 2019-10-25 01:28:18 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can I use PC to the nearest safe haven?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-25 05:28:17 来自手机 | 显示全部楼层
682141 发表于 2019-10-24 18:43:17 Although this guy was an a-hole about it he is correct. Doesn't specifically say 30 minutes or 30 miles, regulations say \"nearest reasonable distance\". Depending on where you are could be 30 miles or 30 minutes. But when you do this your rest time essentially starts when you park to rest. So if you unloaded for 4 hours, ran out of time, then use PC... you are S.O.L. you just lost those 4 hours as rest.
","text":"That is wrong. If you use PC IT IS STILL CONSIDERED AS OFF DUTY AND YOUR REST BREAK CONTINUES EVEN THROUGH YOU DROVE THE TRUCK","replyToPid":234465}
回复 支持 16 反对 1
发表于 2019-10-25 03:14:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"thats not PC you have to use driving time ","replyToPid":0}
回复 支持 13 反对 3
发表于 2019-10-25 02:32:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"you have to put your status off duty PC and in remarks put ordered to move by property owner. \nand look for the nearest truck stop or rest area whichever is closer and your preference. and then you can drive there . once you arrived you have to change your status to off duty or sleeper birth. \nthat's how my company wants me to do , might be little diffrent or same at your company .","replyToPid":0}
回复 支持 16 反对 0
发表于 2019-10-25 01:38:56 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Yes. They added an allowance for going to the nearest safe parking. Talk to your safety people about how they want it documented in remarks and such."}
回复 支持 16 反对 0
发表于 2019-10-25 01:59:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can go. Put PC and in remarks forced to move","replyToPid":0}
回复 支持 15 反对 0
发表于 2019-10-25 02:23:25 来自手机 | 显示全部楼层
677601 发表于 2019-10-24 18:06:18 DOT regulations allow you up to 30 miles “safe heaven” moving after loading -unloading in case you ran out of time. Use your QUALCOM accordingly ....
","text":"BS. Not a single word about 30 miles anywhere in the regs","replyToPid":234442}
回复 支持 14 反对 1
发表于 2019-10-26 04:31:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hey! I'm earning cash just to drive without using my phone with OnMyWay! You can too by signing up at https://r.onmyway.com/YwcVSp4vT0","replyToPid":0}
回复 支持 12 反对 2
发表于 2019-10-26 00:55:22 来自手机 | 显示全部楼层
617350 发表于 2019-10-24 22:36:44 No need to argue.. PC is off duty drive. Read the refs. If you are in PC you are still in off duty. You can rest 4 hours at shipper getting unloaded , run out of hours, and then told to leave, use PC (which is off duty driving) to the closest safe haven, and continue your rest break for 6 more hours then your rest will be complete even though you drove the tru k
","text":"it will mess up an 8-2 sleeper split if you were trying to do that,  since that requires a continuous 8 HR sleeper log","replyToPid":234692}
回复 支持 13 反对 0
发表于 2019-10-25 08:29:23 来自手机 | 显示全部楼层
500185 发表于 2019-10-24 18:23:25 BS. Not a single word about 30 miles anywhere in the regs
","text":"The daily limit is up to 75 kilometers, almost 47 miles, for using a CMV for personal conveyance. In the United States, however, no limit is currently set. Obviously, traveling hundreds of miles isn't going to be considered personal conveyance by a DOT inspector.","replyToPid":234451}
回复 支持 12 反对 1
发表于 2019-10-25 01:55:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes","replyToPid":0}
回复 支持 13 反对 0
发表于 2019-10-25 02:06:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"DOT regulations allow you up to 30 miles “safe heaven” moving after loading -unloading in case you ran out of time. Use your QUALCOM accordingly ....","replyToPid":0}
回复 支持 12 反对 0
发表于 2019-10-25 02:13:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"like everyone else says... yes","replyToPid":0}
回复 支持 13 反对 0
发表于 2019-10-25 02:43:17 来自手机 | 显示全部楼层
","text":"Although this guy was an a-hole about it he is correct. Doesn't specifically say 30 minutes or 30 miles, regulations say \"nearest reasonable distance\". Depending on where you are could be 30 miles or 30 minutes. But when you do this your rest time essentially starts when you park to rest. So if you unloaded for 4 hours, ran out of time, then use PC... you are S.O.L. you just lost those 4 hours as rest.","replyToPid":234451}
回复 支持 13 反对 0
GMT+8, 2026-2-11 03:46 , Processed in 0.144784 second(s), 24 queries .
