查看: 193|回复: 5
Need help with parallel parking
 楼主| 发表于 2019-10-24 00:55:08 来自手机 | 显示全部楼层 |阅读模式
{"text":"Looking for good info and videos on parallel parking. Straight line and offset are no problem but parallel parking is on and off.  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-29 08:18:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"parallel is litterally an offset","replyToPid":0}
发表于 2019-10-24 11:34:59 来自手机 | 显示全部楼层
836417 发表于 2019-10-24 01:28:17 i didnt get much help with videos. i practiced and how i did it was to watch for the tip of the landing gear. got it in everytime
","text":"I was thought 2 ways, one was to check the left tires and the second with the landing gear. Te landing gear method was easier ","replyToPid":234082}
发表于 2019-10-24 07:52:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://www.google.com/search?q=semi+truck+parallel+parking+tips&ie=UTF-8&oe=UTF-8&hl=en-us&client=safari \nhope this helps","replyToPid":0}
发表于 2019-10-24 09:00:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"The best thing I can say is practice. The more you do it, the more the concept will form in your mind of how it works mechanically. Good luck. Ask for extra help from your instructor or trainer. ","replyToPid":0}
发表于 2019-11-5 22:34:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you already have your cdl don't bother.  I've never been in a situation where I needed to parallel park in a rig. I'm amazed they require it in some states. it goes against logic. why choose a never used technique over a 90° dock maneuver that is used everyday at every customer and truckstop?","replyToPid":0}
GMT+8, 2026-4-17 23:06 , Processed in 0.159330 second(s), 24 queries .
