查看: 76|回复: 8
700AM midnight trucking radio show said the Dallas F3 Toronto was on the ground for 20 miles
 楼主| 发表于 2019-10-23 00:25:26 来自手机 | 显示全部楼层 |阅读模式
{"text":"I wonder if it's legal to cheat on your log book to get away from a tornado?","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1632.0,\"name\":\"\",\"url\":\"\",\"width\":1224.0}]","canComment":true}
发表于 2019-10-23 01:51:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Extreme weather exception","replyToPid":0}
发表于 2019-10-23 01:06:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"hahahah","replyToPid":0}
发表于 2019-10-23 01:27:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"IDC about no logs if I gotta run from a tornado!!","replyToPid":0}
发表于 2019-10-23 03:23:11 来自手机 | 显示全部楼层
705502 发表于 2019-10-22 17:51:09 Extreme weather exception
","text":"this guy is correct. It's actually called Inclement weather exception. Gives you 2 extra hours. But if you still don't know how to fix your logbook on ELD you're using the wrong one.","replyToPid":233107}
发表于 2019-10-23 04:46:30 来自手机 | 显示全部楼层
682141 发表于 2019-10-22 19:23:11 this guy is correct. It's actually called Inclement weather exception. Gives you 2 extra hours. But if you still don't know how to fix your logbook on ELD you're using the wrong one.
","text":"Thanks for the correction","replyToPid":233243}
发表于 2019-10-23 06:22:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"adverse conditions aint no dot in there rite mind gonna tell you you cant safley move into a safer haven and if the company writes you up for it well then find a new company cause there sh!t!!! seeing as how you saved there truck and load if ypur an owner opp. then haul a@@ lolololol","replyToPid":0}
发表于 2019-10-23 07:27:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Part 395.1\n(b) Driving conditions—(1) Adverse driving conditions. Except as provided in paragraph (h)(2) of this section, a driver who encounters adverse driving conditions, as defined in §395.2, and cannot, because of those conditions, safely complete the run within the maximum driving time permitted by §§395.3(a) or 395.5(a) may drive and be permitted or required to drive a commercial motor vehicle for not more than 2 additional hours beyond the maximum time allowed under §§395.3(a) or 395.5(a) to complete that run or to reach a place offering safety for the occupants of the commercial motor vehicle and security for the commercial motor vehicle and its cargo.","replyToPid":0}
发表于 2019-10-23 07:31:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"It's not a \"dam it's gonna snow today, so I can now drive 2 more hours rule\"\nIf you knew what the forecast was/is, and drove into that storm, and tried to use the 2 hour rule, you are in violation of your HOS.\nThe rule is very specific, so be careful.\nAnd have a safe ride.","replyToPid":0}
GMT+8, 2026-2-13 07:51 , Processed in 0.102423 second(s), 24 queries .
