查看: 468|回复: 49
wifi hotspot gaming
 楼主| 发表于 2019-10-22 09:57:44 来自手机 | 显示全部楼层 |阅读模式
{"text":"So I game on my off time and I'm tired of my Verizon hotspot always lagging me. I'm looking for a better option if any of you can help me out. Don't recommend any truck stop WiFi please. I tried buying that crap too and it's a waste of money.  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-24 01:24:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"This is a nice post. I am really learning a lot","replyToPid":0}
发表于 2019-10-23 18:01:32 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Nighthawk MR1100. Wireless buy sells it with a data plan on T-mobile for $219 (one time) + $79.99 per month for unthrottled 4G. Used about 250 GB the first 2 weeks, still worked great after. Unlike other services that say they're unlimited, but cap 4G at like 50GB. I think there's a code for the plan though for $10 off. Try CODE10 if you decide to go with them.\n\nForgot to mention, we usually have 2 gaming laptops connected to it. We play Destiny 2 or Apex. Solo games work well as well."}
 楼主| 发表于 2019-10-23 06:22:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have the jetpack too and it sucks. my updates eat all the data up and then I'm stuck without any data to even play the game. so tired of paying for hotels to update my games so I chucked the jetpack out the window.","replyToPid":0}
回复 支持 2 反对 2
 楼主| 发表于 2019-10-23 06:17:52 来自手机 | 显示全部楼层
628831 发表于 2019-10-22 20:01:12 OTR mobile works awesome
","text":"it says they don't offer open NAT type. what games are you playing on it?","replyToPid":233331}
回复 支持 2 反对 2
 楼主| 发表于 2019-10-23 06:12:21 来自手机 | 显示全部楼层
599477 发表于 2019-10-22 20:07:26 Get a good home modem/router and get Netbuddy 😁
","text":"which model did you get and how much did you spend on everything?","replyToPid":233337}
回复 支持 2 反对 2
 楼主| 发表于 2019-10-23 06:10:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"was it used? what does no throttling mean? and how much a month? I'm trying to get a price estimate overall so I can save up","replyToPid":0}
回复 支持 2 反对 2
发表于 2019-10-23 06:40:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"The connection is still throttled by whatever company that owns the node you are connected to. \nBS to any company that says they do not throttle. I can prove with 100% certainty otherwise. \nThe nodes that you are connecting to can only handle so much traffic per channel per band and no company wants to keep a connection that's constantly open and providing top speed when that would mean no one else could connect to that particular node without greatly reducing their connection speeds.\nThat's just networking 101","replyToPid":0}
发表于 2019-10-23 06:30:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks for this post, I’ve been thinking about the same lately. I mostly use hotspot but it’s shooting when the download speeds are at kB","replyToPid":0}
发表于 2019-10-23 03:50:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"hmm, connection speeds are determined by the whatever tower (cell) or WiFi modem|router is throttled or limited to and also distance and hops, etc... ping times. Long ping equals lag basically. Many things can cause lagged connection's. Connection's do not go in a straight line or from directly from point to point. That is one reason of many that a connections speed can be fine one moment and lag or even completely drop the next. \nThen there is your provider... they ALL suck at providing a stable mobile connection throughout the USA. Even if you are not moving.","replyToPid":0}
发表于 2019-10-23 02:31:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Honestly Verizon jet pack is the best there is right now. \n\nDon’t use your phone as a hotspot. I play dota 2 rocket league and counter strike with no lag. \n\nI have the new jet pack that has the extra antennas ","replyToPid":0}
发表于 2019-10-23 02:41:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use the hotspot on my phone when I play online on my down time aswell no lag I have t mobile.","replyToPid":0}
 楼主| 发表于 2019-10-23 03:04:38 来自手机 | 显示全部楼层
542330 发表于 2019-10-22 18:31:37 Honestly Verizon jet pack is the best there is right now. \n\nDon’t use your phone as a hotspot. I play dota 2 rocket league and counter strike with no lag. \n\nI have the new jet pack that has the extra antennas
","text":"which model?","replyToPid":233133}
发表于 2019-10-23 03:13:48 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"this is the only solution that will work.You need a 4g modem, especially one that will take MiMo antennas. The newest 4g router is the Netgear nighthawk M1. A more expensive and better alternative is the Mofi 4500 GXeLTE. If you have a data tablet plan all you do is put in your sim card in it. IF YOU WANT TRUE 4G UNTHROTTLED UNLIMITED DATA then you need to get a sim card from T-Mobile, the cheapest place to get it is from Wireless Buy. This is a business sim card if you get a personal one from t mobile it wont be true unlimited or unthrottled. This is from personal experience. I found out about this from Supreme Builds on You Tube and it's a total life changer. Search netgear m1 supreme builds and watch the video. this way you can also have the direct ethernet connection from the modem."}
发表于 2019-10-23 03:14:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"I play Apex and Destiny on off my hotspot for Verizon but I got Foxfi on one of my phone so I got a free tether app on my phone. if you want the best hotspot model I recommend an Unlocked AT&T Nighthawk it comes with a ether etc. cable and has multiple broadband to give you a better service. Check it out I never have a problem.","replyToPid":0}
发表于 2019-10-23 03:19:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have 2 phones S10E and a S6 Plus I have Verizon Unlimited Plus that gives me 20 GB of 4G LTE Hotspot, when I run out I switch over from my S10E to my S6 Plus due to the fact that the app software is only compatible with older android phones, (Foxfi) which allows me to my mask my tethering as my phones data usage.","replyToPid":0}
 楼主| 发表于 2019-10-23 03:42:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks guys I have some searching to do now!","replyToPid":0}
发表于 2019-10-23 04:01:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"OTR mobile works awesome","replyToPid":0}
GMT+8, 2026-2-11 07:13 , Processed in 0.129436 second(s), 24 queries .
