查看: 118|回复: 7
5G and your Qualcomm going to cook drivers like a hard boiled egg?
 楼主| 发表于 2019-10-22 04:31:15 来自手机 | 显示全部楼层 |阅读模式
{"text":"radio talk show talked about dangers of 5G . and the Qualcomm's in truck's are being replaced with 5G . that might make driver's sick and wreak the truck","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1632.0,\"name\":\"\",\"url\":\"\",\"width\":1224.0}]","canComment":true}
发表于 2019-10-22 11:45:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"You ever smell some of these drivers at the truck stop? Believe you me, they are already wreaking the truck! 🤣","replyToPid":0}
发表于 2019-10-22 12:37:57 来自手机 | 显示全部楼层
817113 发表于 2019-10-22 04:09:15 Are you serious?  Why would the carriers want to make the switch? What's the up side of 5G?
","text":"It’s just faster.  It there’s no real benefit since the range sucks ","replyToPid":232935}
发表于 2019-10-22 05:47:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Also many companies dropped Qualcomm for cheaper and more reliable eld","replyToPid":0}
发表于 2019-10-22 05:38:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"5G only has a range of about 100-300 ft from a tower. It won’t even work in the truck unless truck stops and terminals start planting 5G towers. ","replyToPid":0}
发表于 2019-10-22 12:09:15 来自手机 | 显示全部楼层
497499 发表于 2019-10-21 21:38:16 5G only has a range of about 100-300 ft from a tower. It won’t even work in the truck unless truck stops and terminals start planting 5G towers.
","text":"Are you serious?  Why would the carriers want to make the switch? What's the up side of 5G?","replyToPid":232676}
发表于 2019-10-22 22:44:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"I only wreak the truck after using the Thunder Bucket","replyToPid":0}
发表于 2019-10-23 02:38:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"just like cell phones and 4G and all the new technology was suppose. this stupid species will never die off unfortunately! we adapt our surroundings to much instead of the other way around. cant wait for mother nature to feast","replyToPid":0}
GMT+8, 2026-2-13 06:10 , Processed in 0.129904 second(s), 24 queries .
