查看: 111|回复: 2
How many times do you change your tires in a year?
 楼主| 发表于 2019-10-22 04:25:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"twice? thrice?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-22 05:56:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Never company I drive for buys new trucks and trades the old ones every 2-3 years. ","replyToPid":0}
发表于 2019-10-23 08:30:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you are changing tires yearly, either you have a mechanical issue or your just doing it wrong.\nDon't buy cheap Chinese tires.\nDrives should last between 300k and 400k\nSteers should last 90k to 150k.\nDo not \"dry steer\"\nIf the truck is sitting still, the steering wheel should be still.\nOnly steer if vehicle is actually moving","replyToPid":0}
GMT+8, 2026-4-21 13:32 , Processed in 0.063214 second(s), 25 queries .
