查看: 72|回复: 5
I need a new wiper blade 😡
 楼主| 发表于 2019-10-21 10:55:31 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[{\"url\":\"http://d2w8udw005hdju.cloudfront.net/video/146011/android_747109_1571626497750.mp4\"}]","link":"{}","pics":"[{\"description\":\"\",\"height\":1080.0,\"name\":\"\",\"url\":\"\",\"width\":1863.0}]","canComment":true}
发表于 2019-10-21 14:05:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"shaving cream on the inside of the windshield will stop it from fogging up as well","replyToPid":0}
发表于 2019-10-21 11:25:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"You need to turn your defrost off put your heater on the floor with the a/c on. Ice won’t stick to anything that’s the same temp as it is.","replyToPid":0}
发表于 2019-10-21 12:09:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"unprepared not good","replyToPid":0}
 楼主| 发表于 2019-10-21 12:40:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"yeah man ! that's me","replyToPid":232200}
 楼主| 发表于 2019-10-21 12:43:13 来自手机 | 显示全部楼层
64567 发表于 2019-10-21 03:25:33 You need to turn your defrost off put your heater on the floor with the a/c on. Ice won’t stick to anything that’s the same temp as it is.
","text":"thanks for the info , will try that right now","replyToPid":232177}
GMT+8, 2026-2-13 04:27 , Processed in 0.120676 second(s), 24 queries .
