查看: 81|回复: 2
Police Training Flight Ends in Crash Into Semi-Trailer
 楼主| 发表于 2019-10-20 02:35:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"Stockton, CA – A single-engine plane being flown by two San Joaquin County Sheriff’s deputies was forced to make an emergency landing shortly after takeoff, and accidentally crash landed into a semi-trailer.\n\nA spokesperson from the San Joaquin County Sheriff’s Department (SJCSD) said the plane took off from the Stockton Airport around 6:25 p.m. on Thursday.\n\nRead more: https://transportationnation.com/police-training-flight-ends-in-crash-into-semi-trailer/  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-20 06:51:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"This is your fault, US government, for not regulating airspace properly. We shouldn’t have aircraft equipped with only one engine with no onboard redundancy in place. ","replyToPid":0}
发表于 2019-10-20 10:20:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"I bet it was the truckers fault!!! It’s always the truckers fault Check his Logs and make him do a pee test !!","replyToPid":0}
GMT+8, 2026-2-8 02:15 , Processed in 0.067804 second(s), 23 queries .
