查看: 215|回复: 5
Hi guys, i need your quick help, on my way to Washington, the DOT weigh station in Butte, is it on I-90 or I-15?
 楼主| 发表于 2019-10-19 05:07:41 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-10-19 06:36:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s on both- in the middle of the stretch where both highways use the same concrete. \nThere’s construction all through the area, but when I went through a week ago, the westbound scale was open","replyToPid":0}
发表于 2019-10-19 06:05:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"map says I15","replyToPid":0}
 楼主| 发表于 2019-10-19 06:41:52 来自手机 | 显示全部楼层
157862 发表于 2019-10-18 22:36:39 It’s on both- in the middle of the stretch where both highways use the same concrete. \nThere’s construction all through the area, but when I went through a week ago, the westbound scale was open
","text":"Ok thanks bro.","replyToPid":230842}
发表于 2020-1-5 03:39:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"both.","replyToPid":0}
发表于 2020-1-5 03:40:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"90 and  15 are the same for a short time","replyToPid":0}
GMT+8, 2026-3-21 12:37 , Processed in 0.050296 second(s), 24 queries .
