查看: 116|回复: 2
Studies show most areas that outlaw engine breaks are on flat ground and you don't need them anyway!!...
 楼主| 发表于 2019-10-19 02:18:46 来自手机 | 显示全部楼层 |阅读模式
{"text":"Unless you like wasting fuel to wake up the neighborhood!!\n","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":960.0,\"name\":\"\",\"url\":\"\",\"width\":960.0}]","canComment":true}
发表于 2019-10-19 03:15:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"\nIf you require braking, don't use the vehicle brakes, use engine braking first. When your engine increases beyond it's idle speed the ECU stops sending fuel to the cylinders as it is not required. Your kinetic energy is being used to overcome the friction in the engine (and power accesories etc...so how is it wasting fuel? You’re slowing down not accelerating. Just because the engine is making more noise doesn’t mean it’s burning fuel...it only means the exhaust valves have closed in the head. 👍","replyToPid":0}
发表于 2019-10-19 03:54:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"😅😅😅","replyToPid":0}
GMT+8, 2026-4-21 04:40 , Processed in 1.530419 second(s), 24 queries .
