查看: 77|回复: 4
Getting over after passing
 楼主| 发表于 2019-10-19 01:31:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"If I flash my lights to get over and then the driver drives a mile down the road and finally gets over. What’s up with that? Is it an ego thing? Just get over ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-19 07:27:14 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"because of the glare of your lights in my mirrors can be blinding. Farthet up i am less i have to take that glare especially if you're behind me flashing your lights, why not hit your marker lights instead? I'd rather a driver not flash any kind of lights when i pass them, if i cant tell that i can get over without someone flashing ligbts then i probably dont need to be in that drive seat. thats just me though too each their own"}
发表于 2019-10-22 10:06:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Rule number 1. never Flash your lights. Always turn them off and back on. You can blind the driver. And when you pass and get over make sure you thank them by using your four ways or the switch the turns off your clearance lights. that's the way I was taught to do it.","replyToPid":0}
 楼主| 发表于 2019-10-22 01:42:16 来自手机 | 显示全部楼层
836938 发表于 2019-10-18 23:27:14 because of the glare of your lights in my mirrors can be blinding. Farthet up i am less i have to take that glare especially if you're behind me flashing your lights, why not hit your marker lights instead? I'd rather a driver not flash any kind of lights when i pass them, if i cant tell that i can get over without someone flashing ligbts then i probably dont need to be in that drive seat. thats just me though too each their own
","text":"Wel I drive an international so I don’t flash, it just blinks my headlights ","replyToPid":230872}
 楼主| 发表于 2019-10-23 00:53:31 来自手机 | 显示全部楼层
838767 发表于 2019-10-22 02:06:09 Rule number 1. never Flash your lights. Always turn them off and back on. You can blind the driver. And when you pass and get over make sure you thank them by using your four ways or the switch the turns off your clearance lights. that's the way I was taught to do it.
","text":"I just said that I don’t flash my lights. ","replyToPid":232839}
GMT+8, 2026-4-21 11:41 , Processed in 0.076029 second(s), 25 queries .
