查看: 41|回复: 0
As winter slowly approach over the horizon.
 楼主| 发表于 2019-10-19 01:25:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"These are somethings you should have with You. Bleach to help gain traction on tires. Kitty Litter to do the same thing. Ice melt simple Rubbing alcohol to put into your airline to keep from brakes freezing. \n\nA hammer to help brakes become unstuck. Also can put alcohol in fuel tanks n mix with windshield washer fluid. An old pair of socks to put over your wiper blades to keep the snow from building up. Water can goods soup dry fruit nuts extra blankets n a snowsuit.\n\n","videos":"[]","link":"{}","pics":"[]","canComment":true}
GMT+8, 2026-4-21 02:50 , Processed in 0.081862 second(s), 23 queries .
