查看: 275|回复: 4
Just switched to 2019 Cascadia today my International broke down, lights won't turn off.
 楼主| 发表于 2019-10-18 10:13:30 来自手机 | 显示全部楼层 |阅读模式
{"text":"2019 Cascadia the lights for my side boxes are still on. I double checked the doors and they're fully closed and my bunk is completely shut, I lifted the bunk and pressed the button down similar to the one in a fridge but they still won't turn off. I have made sure everything is closed properly but I can still see light leaking under the bunk. Anyone else ever dealt with this any suggestions are appreciated. ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-18 10:21:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Turn off the switch before going to sleep which is located close to left door on the floor ","replyToPid":0}
发表于 2019-12-3 22:34:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"There is a switch behind the hinge on the side doors. Bracket very easy to bend. Mine were on for weeks before I found it","replyToPid":0}
发表于 2019-10-18 10:24:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"check under each light they have their own independent switch","replyToPid":0}
发表于 2019-10-19 01:06:49 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I have same problem, that light is not switch off, just dont pay attention "}
GMT+8, 2026-4-17 06:07 , Processed in 0.120458 second(s), 24 queries .
