查看: 117|回复: 5
Switching divisions
 楼主| 发表于 2019-10-17 09:05:51 来自手机 | 显示全部楼层 |阅读模式
{"text":"Searching dryvan for flatbed but getting automatic truck now","videos":"[]","link":"{}","pics":"[]","canComment":true}
 楼主| 发表于 2019-10-17 11:24:44 来自手机 | 显示全部楼层
235536 发表于 2019-10-17 02:07:00 most newer trucks  the bigger companies are buying now a days are automatic it seems hell been out here flatbeding 18yrs shifting gears adjusting clutches hearing a lot of  talk about automatic transmissions I've been thinking it be.nice in traffic and other situations where it's shift shift shift just mash that fuel peddle and go
","text":"Ya guess can knock it till I try it at least they rent governed","replyToPid":229618}
发表于 2019-10-17 10:07:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"most newer trucks  the bigger companies are buying now a days are automatic it seems hell been out here flatbeding 18yrs shifting gears adjusting clutches hearing a lot of  talk about automatic transmissions I've been thinking it be.nice in traffic and other situations where it's shift shift shift just mash that fuel peddle and go","replyToPid":0}
发表于 2019-10-17 11:30:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"well that's a positive I'm gov at 62 and still not fully adjusted after 6 months going 62","replyToPid":0}
发表于 2019-10-17 12:48:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"I mean automatic isn’t all that bad. You have just have to focus on the positives with it. It took me a little while to get use to it in the mountains especially with the heavier loads but it’s not all bad. ","replyToPid":0}
发表于 2019-10-17 12:51:07 来自手机 | 显示全部楼层
235536 发表于 2019-10-17 03:30:17 well that's a positive I'm gov at 62 and still not fully adjusted after 6 months going 62
","text":"Good lord, 62 are you with TMC. I can get use to a automatic but not that speed. ","replyToPid":229711}
GMT+8, 2026-4-19 11:54 , Processed in 0.073497 second(s), 24 queries .
