查看: 86|回复: 2
Taxes
 楼主| 发表于 2019-10-17 03:59:32 来自手机 | 显示全部楼层 |阅读模式
{"text":"is a bank statement good enough for taxes or do you need receipts?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-17 13:42:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"You need actual receipts. ","replyToPid":0}
发表于 2019-10-17 22:45:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"your statement is good enough. it just has to match your logs or travel calendar. why are you still doing receipts use the per diem! I understand receipts for other expenses but you should be doing per diem a lot better than logging and saving receipts.","replyToPid":0}
GMT+8, 2026-4-18 07:25 , Processed in 0.082240 second(s), 24 queries .
