查看: 131|回复: 10
Why can none of you get the hell out of the center lane?
 楼主| 发表于 2019-10-17 01:18:57 来自手机 | 显示全部楼层 |阅读模式
{"text":"What happened to keep right unless passing?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-18 06:12:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"in some highway, too many cars pulling in to merge, so some truckers dont want to be entering center lane and back to right lane repeatedly. it might be considered unsafe just constantly change lanes every mile","replyToPid":0}
发表于 2019-10-17 20:14:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"the center lane is the travel lane. the right lane is for entering/exiting the freeway. the left lane is for passing.","replyToPid":0}
发表于 2019-10-17 15:34:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"they can get out of the center lane but choose not to  most of these middle Lane drivers are have no common sense let alone common courtesy for a fellow drivers they don't care or no idea there messing.up traffic especially.seeimg two trucks gov same speed.side.by side drivers both white knuckles on the wheel for miles and miles some of them","replyToPid":0}
发表于 2019-10-18 05:23:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"If there’s more than two lanes and my truck will go the speed limit, I’ll often choose to keep the right lane open for merging traffic. Unless signage indicates otherwise. ","replyToPid":0}
发表于 2019-10-17 16:51:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'll drive in whatever Lane I want.","replyToPid":0}
发表于 2019-10-17 14:59:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"lol!! you ever been through the stretch of i95 from the Gearge washington bridge to the 91/95 interchange? I've never seen a truck driver in the right lane unless they were exiting you can tell it's customary because of the sunken in grooves as well","replyToPid":0}
发表于 2019-10-18 06:18:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"it depends on traffic.  if there is constant merging I will scoot into the center lane.  there's still a left lane for passing so why get bothered by it?","replyToPid":0}
发表于 2019-10-17 19:34:04 来自手机 | 显示全部楼层
479278 发表于 2019-10-17 08:51:54 I'll drive in whatever Lane I want.
","text":"because you are Patriots Fan=Cheaters","replyToPid":229839}
发表于 2019-10-18 00:10:25 来自手机 | 显示全部楼层
597174 发表于 2019-10-17 11:34:04 because you are Patriots Fan=Cheaters
","text":"fake news","replyToPid":229855}
GMT+8, 2026-2-10 01:23 , Processed in 0.064705 second(s), 24 queries .
