查看: 298|回复: 16
First winter this year
 楼主| 发表于 2019-10-15 08:53:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"This will be my first winter. I’m from Houston. Looking for road wisdom,recommended items and do’s and Don’ts please keep that negativity to yourself thanks\n\n-hotdog Johnson 🌭","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-15 10:32:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"just go at a speed your comfortable with no Jake brake on icy roads and when you don't see any moisture kicking up from the tires well your on ice be safe stay calm and confident","replyToPid":0}
发表于 2019-10-15 11:23:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"When in doubt, shut it down. It's not worth your life or the life of others for a few miles more in unfavorable conditions.","replyToPid":0}
发表于 2019-10-15 11:49:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"If your company gives you grief for shutting down when you don’t feel safe, find a better company. ","replyToPid":0}
发表于 2019-10-15 11:47:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don’t take chances with ice. Going through Montana last week the ice was so severe I was going 24mph and still loose, so I shutdown for two days and rescheduled my load. When in doubt, don’t go out. ","replyToPid":0}
发表于 2019-10-15 11:42:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t use cruise control in bad conditions. And if roads are bad don’t be a fool throw chains. Your safety is more important then the load. ","replyToPid":0}
发表于 2019-10-15 21:37:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"know your limits if it looks too bad it probably is know when to stop! and slow down no engine brake and no cruise","replyToPid":0}
 楼主| 发表于 2019-10-15 10:56:01 来自手机 | 显示全部楼层
235536 发表于 2019-10-15 02:32:36 just go at a speed your comfortable with no Jake brake on icy roads and when you don't see any moisture kicking up from the tires well your on ice be safe stay calm and confident
","text":"👌🏽 thx stay safe out there ","replyToPid":227938}
 楼主| 发表于 2019-10-15 11:52:57 来自手机 | 显示全部楼层
705502 发表于 2019-10-15 03:23:52 When in doubt, shut it down. It's not worth your life or the life of others for a few miles more in unfavorable conditions.
","text":"Thx stay safe ","replyToPid":227990}
 楼主| 发表于 2019-10-15 11:53:27 来自手机 | 显示全部楼层
771835 发表于 2019-10-15 03:42:57 Don’t use cruise control in bad conditions. And if roads are bad don’t be a fool throw chains. Your safety is more important then the load.
","text":"Thx stay safe ","replyToPid":228006}
 楼主| 发表于 2019-10-15 11:54:58 来自手机 | 显示全部楼层
497499 发表于 2019-10-15 03:49:12 If your company gives you grief for shutting down when you don’t feel safe, find a better company.
","text":"Thx stay safe ","replyToPid":228013}
GMT+8, 2026-4-19 22:43 , Processed in 0.092692 second(s), 24 queries .
