查看: 302|回复: 12
placr calls for close toe shoes
 楼主| 发表于 2019-10-15 05:21:28 来自手机 | 显示全部楼层 |阅读模式
{"text":"he saids socks count as close toe shoes wat ever happend to jeans and boots","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2080.0,\"name\":\"\",\"url\":\"\",\"width\":1560.0}]","canComment":true}
 楼主| 发表于 2019-10-15 11:05:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"hopefully ine day he will learn a lesson","replyToPid":0}
回复 支持 3 反对 2
发表于 2019-10-15 09:50:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"he be crying if something smashes his toe","replyToPid":0}
发表于 2019-10-15 10:44:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"the person he asked should have smashed his foot with a closed toed shoe","replyToPid":0}
发表于 2019-10-15 15:42:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"He hires a lumper. No boots needed. He runs cruise control for 10 hrs. No boots needed. He walks to the sro. No boots needed. If you want sweaty boots skunking up your truck at days end so you can pretend to be Burt Reynolds that’s on you. ","replyToPid":0}
发表于 2019-10-17 01:06:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m tired of these places wanting me to wear a vest, hard hat and steel toe shoes. If something falls on the truck a hard hat won’t help, I’m not on the dock so why do I need steel toe? A safety vest doesn’t work either since I sit in the truck to be loaded. ","replyToPid":0}
发表于 2019-10-15 11:41:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"(Common sense has left the building.)","replyToPid":0}
发表于 2019-10-15 11:56:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"fork lifts are hell on that type of footwear.  steel toes help a bit. \nbut if you have to go on the dock to count your load. ya might want to protect your toes","replyToPid":0}
发表于 2019-10-17 07:44:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"common sense is not so common","replyToPid":0}
发表于 2019-10-18 23:31:28 来自手机 | 显示全部楼层
705502 发表于 2019-10-15 03:41:17 (Common sense has left the building.)
","text":"🤣😂🤣😂🤣 So True","replyToPid":228005}
GMT+8, 2026-4-19 11:53 , Processed in 0.108096 second(s), 24 queries .
