查看: 150|回复: 7
Can you get a local job with no experience?
 楼主| 发表于 2019-10-13 03:54:05 来自手机 | 显示全部楼层 |阅读模式
{"text":"Is it possible?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-13 09:04:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes, if you got a CDL you can get hired.  My first job was driving a 53 ft Landoll I had no experience other than school.  To be honest with you I couldn't even shift the gears correctly and I got the job.  Companies are out there that will put you to work but I would encourage you to get with a trainer and learn the right way. Be safe & good luck.","replyToPid":0}
发表于 2019-10-14 00:42:13 来自手机 | 显示全部楼层
发表于 2019-10-13 15:36:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"I started at a small seafood company first class B straight reefer trucks delivering to restaurants bars and grocery stores back in the paper log times use to work 3am to 5 or 6 pm monday to friday, it wasn't too bad until sysco bought them out and heavily regulated everything. You're gonna work wayy harder at any local spot just keep that in mind","replyToPid":0}
发表于 2019-10-13 10:22:57 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Coca Cola and Pepsi will train you with no experience, but it’s demanding work "}
发表于 2019-10-13 12:54:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can get a over the road job for me if interested. It’s a good pay ","replyToPid":0}
发表于 2019-10-13 20:57:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"some places","replyToPid":0}
发表于 2019-10-22 09:32:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Boils down to do you know somebody","replyToPid":0}
GMT+8, 2026-4-18 07:26 , Processed in 0.093149 second(s), 24 queries .
