查看: 186|回复: 19
S
 楼主| 发表于 2019-10-12 21:33:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[]","canComment":false}
发表于 2019-10-12 22:32:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"I pull a reefer. an when it defrost it runs wide open.  I was. told to always try to park next to a carcarrier if at all possible. I asked. why they was told it's was rule number 1 .","replyToPid":0}
回复 支持 6 反对 0
发表于 2019-10-12 22:47:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"lol at the whiney guy.   Ive pull reefer always try to park away from others, hell rest areas are my first choice, now I'm dry van. and still try not to park at truckstops.  too many whiners too many accidents and a bunch of CB warriors.","replyToPid":0}
发表于 2019-10-12 22:08:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Globetrotter...seriously dude, chill the hell out.  You think your the ONLY driver out there that works hard and enjoys a good nights sleep?  On a side note, there’s enough Outsiders trying to tear this industry apart, I don’t think it beneficial to tear each other to shreds from within the industry...unless you’re “one of them”.  Resolution to your complaint.....buy a set of ear plugs...PROBLEM SOLVED.  There, that’s my 2 cents worth, feel free to keep the change!!!","replyToPid":0}
发表于 2019-10-12 22:22:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Exercise much do ya...not a reefer driver.  It’s common sense and self preservation.  Quit your d@mn whining, build a bridge and get the hell over yourself.  ","replyToPid":0}
发表于 2019-10-12 22:47:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Try playtex,  lol. ","replyToPid":0}
发表于 2019-10-13 04:17:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Being a reefer driver, I understand where you're coming from, and I normally try to get a spot away from non-reefer trucks and sometimes it is not possible. Besides, think about the trucks with APUs that are worse than the trailers. Invest in those earplugs bud","replyToPid":0}
发表于 2019-10-13 02:50:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Oh sorry flower, we didn’t mean to ruin your petals. Reefer sound is the Temp Controlled Division’s lullaby, as nice as Coal Miner’s Cough. 😂 ","replyToPid":0}
发表于 2019-10-13 02:26:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Reefer training rule #3.. ALWAYS PARK BY A NONE RUNNING CAR HAULER WHEN POSSIBLE.. if not possible blunt up beside a SWIFT truck. ","replyToPid":0}
发表于 2019-10-13 00:31:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"I pull reefer and I try not to park next to a quite truck but sometimes you don’t have a choice then I put my reefer on  continuous so it idles but when they go in defrost they will go on high most reefers are is quite as a APU ","replyToPid":0}
 楼主| 发表于 2019-10-12 22:33:01 来自手机 | 显示全部楼层
270970 发表于 2019-10-12 14:22:35 Exercise much do ya...not a reefer driver.  It’s common sense and self preservation.  Quit your d@mn whining, build a bridge and get the hell over yourself.
","text":"I use to pull refer many years ago and I know exactly what it is and if I have a chance to park further away from none refer then I will \nBut what you talking son it’s just out of respect ","replyToPid":226165}
发表于 2019-10-12 21:57:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"bro i run dryvan but in all honesty where are they soppose to sleep they have to run the reefer dose loads have to stay at a vertain tempture of theres a drop in temp the reciver can tell and they wont accept the load i use to run reefer before its jusy part of the job bro get some earmuffs or something to block ur ears while u sleep..","replyToPid":0}
发表于 2019-10-12 21:57:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Globetrotter has never seen such bull$hit","replyToPid":0}
 楼主| 发表于 2019-10-12 22:04:01 来自手机 | 显示全部楼层
815562 发表于 2019-10-12 13:57:42 bro i run dryvan but in all honesty where are they soppose to sleep they have to run the reefer dose loads have to stay at a vertain tempture of theres a drop in temp the reciver can tell and they wont accept the load i use to run reefer before its jusy part of the job bro get some earmuffs or something to block ur ears while u sleep..
","text":"Bro I’m not talking about east coast truck-stops where it’s no room and completely understandable \nI’m talking about lots size of airport truckers paradise and they like a magnet com right next to you ","replyToPid":226149}
 楼主| 发表于 2019-10-12 22:13:29 来自手机 | 显示全部楼层
270970 发表于 2019-10-12 14:08:19 Globetrotter...seriously dude, chill the hell out.  You think your the ONLY driver out there that works hard and enjoys a good nights sleep?  On a side note, there’s enough Outsiders trying to tear this industry apart, I don’t think it beneficial to tear each other to shreds from within the industry...unless you’re “one of them”.  Resolution to your complaint.....buy a set of ear plugs...PROBLEM SOLVED.  There, that’s my 2 cents worth, feel free to keep the change!!!
","text":"That’s how refer drivers react \nJust use your brain this is huge field you can park anywhere you want, why ruin some one night ","replyToPid":226157}
 楼主| 发表于 2019-10-12 22:35:56 来自手机 | 显示全部楼层
695120 发表于 2019-10-12 14:32:03 I pull a reefer. an when it defrost it runs wide open.  I was. told to always try to park next to a carcarrier if at all possible. I asked. why they was told it's was rule number 1 .
","text":"I like that at least some humor this morning ","replyToPid":226170}
GMT+8, 2026-2-12 15:59 , Processed in 0.064554 second(s), 24 queries .
