查看: 313|回复: 13
S
 楼主| 发表于 2019-10-12 21:31:08 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[]","canComment":false}
发表于 2019-10-13 02:35:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'll park next to you.... because I can .","replyToPid":0}
回复 支持 4 反对 1
发表于 2019-10-13 01:01:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Reefers are like big refrigerators, they have to stay running wheather its on high or low cycle. As a newbie you have 2 choices ... 1- get use to it, and 2- quit and work in another career field  .....","replyToPid":0}
发表于 2019-10-13 02:52:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"no different than someone running their truck all night next to me because they done have an APU.  at 2am you get in where you fit in. everyone parks where parking is available. it is what it is.","replyToPid":0}
发表于 2019-10-12 23:46:30 来自手机 | 显示全部楼层
456441 发表于 2019-10-12 14:53:03 I don’t drive reefer but I have to assume it’s cause you’re parked near the building. If you park a certain distance away you won’t see and vans or reefers
","text":"when I drove a reefer I had the loudest POS engine on that darn thing and I was still able to sleep. can't really be a light sleeper and run trucks. Reefers have no choice on if the engine is going to run on high idle or not.","replyToPid":226196}
发表于 2019-10-13 05:52:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s not just ref drivers others do that drives me insane. I always put at least one parking spot between me and other guys in an empty lot. Ref noise doesn’t bother me, its about exaust: let that exhaust blow on through, no need to choke each other out with fumes if we’re idling.","replyToPid":0}
发表于 2019-10-13 11:53:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"when I pulled reefers .. if I had the chance. i would park facing the other way of the other Rig unless it was another Refeer trl","replyToPid":0}
发表于 2019-10-13 00:39:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"I can’t sleep without that soothing hum of my reefer running. It’s like white noise to me. ","replyToPid":0}
发表于 2019-10-12 22:53:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don’t drive reefer but I have to assume it’s cause you’re parked near the building. If you park a certain distance away you won’t see and vans or reefers ","replyToPid":0}
 楼主| 发表于 2019-10-12 23:16:52 来自手机 | 显示全部楼层
","text":"?????","replyToPid":226196}
{"replyTo":"","text":"I drive dry van on empty lots I like to park next to another truck refer or van cuz of🤗","replyToPid":0}
发表于 2019-10-13 01:28:09 来自手机 | 显示全部楼层
{"replyToPid":226226,"replyTo":"
336899 发表于 2019-10-12 15:46:30 when I drove a reefer I had the loudest POS engine on that darn thing and I was still able to sleep. can't really be a light sleeper and run trucks. Reefers have no choice on if the engine is going to run on high idle or not.
","text":"I never said I had trouble sleeping near them. I don’t care if you park next to me weather im idling or not. Plus most of the time I shut down it’s early afternoon and when I leave early in the morning it’s usually other flatbeds around me. "}
 楼主| 发表于 2019-10-13 02:02:56 来自手机 | 显示全部楼层
64741 发表于 2019-10-12 17:01:31 Reefers are like big refrigerators, they have to stay running wheather its on high or low cycle. As a newbie you have 2 choices ... 1- get use to it, and 2- quit and work in another career field  .....
","text":"Newbie haha son","replyToPid":226261}
GMT+8, 2026-4-18 00:51 , Processed in 0.108733 second(s), 24 queries .
