查看: 151|回复: 7
Workouts
 楼主| 发表于 2019-10-12 19:36:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"Just got done with my dumbbells. Probably the best set of dumbbells out there in my opinion. What do you like to workout with? Or what type of workouts do you do while on the road?","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1280.0,\"name\":\"\",\"url\":\"\",\"width\":720.0}]","canComment":true}
 楼主| 发表于 2019-10-13 08:22:47 来自手机 | 显示全部楼层
815562 发表于 2019-10-12 13:59:47 hey brother dose dumbells r great may i suggest that you also get some resistance bands ull be able to incorporate more workouts into your rutine they r great for the pump and helo build muscle aswell
","text":"I was thinking about getting some resistance bands. Thanks for the info","replyToPid":226151}
发表于 2019-10-12 21:59:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"hey brother dose dumbells r great may i suggest that you also get some resistance bands ull be able to incorporate more workouts into your rutine they r great for the pump and helo build muscle aswell","replyToPid":0}
发表于 2019-10-13 04:54:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"nice","replyToPid":0}
发表于 2019-10-13 08:30:49 来自手机 | 显示全部楼层
361664 发表于 2019-10-12 22:39:18 Nice set. I’ve used some similar. \n\nOnce upon a lifetime ago pre trucking, I use to go really hard in the fitness industry (NFPT Certified). \n\nI hit Planet 🌎 Fitnesses out here now on the road when I can. $22 monthly Black Card membership, all over the USA. The massage, tanning, and showers are worth it alone. Many times I use Google Earth app to see if I can park behind the building, usually a massive grocery store area, and drive my truck and trailer there or bobtail or Uber.
","text":"same here with l.a fitness my brother was thinking planet fitness as well to gove me more options","replyToPid":226502}
 楼主| 发表于 2019-10-13 08:24:02 来自手机 | 显示全部楼层
","text":"I don’t used to use planet fitness but I live I southeast ga and I’m home every week. So the tanning part is no problem and the weather right now is perfect to run and workout in!","replyToPid":226502}
发表于 2019-10-13 15:54:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"I keep two 30lb dumbells in the truck and if I'm bobtail with some time i try to personally convey myself to an LA fitness if I'm near one","replyToPid":0}
发表于 2019-10-13 06:39:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nice set. I’ve used some similar. \n\nOnce upon a lifetime ago pre trucking, I use to go really hard in the fitness industry (NFPT Certified). \n\nI hit Planet 🌎 Fitnesses out here now on the road when I can. $22 monthly Black Card membership, all over the USA. The massage, tanning, and showers are worth it alone. Many times I use Google Earth app to see if I can park behind the building, usually a massive grocery store area, and drive my truck and trailer there or bobtail or Uber. ","replyToPid":0}
GMT+8, 2026-3-21 16:37 , Processed in 0.072980 second(s), 24 queries .
