查看: 134|回复: 0
I need to wire a radio to a 2010 freightliner cascadia plz help
 楼主| 发表于 2019-1-24 18:38:55 来自手机 | 显示全部楼层 |阅读模式
{"text":"I need to wire a radio to a 2010 freightliner cascadia but when I was done wiring up the radio and turned the key to the on position the dash light , all of the lights were flashing and all I did was cut the factory wiring harness and hard wired to the back of the radio nothing more.... When I was feeding the amp kit wires through the dash could I have knocked something loose or am I missing a ground I'm lost on this one","pics":"[]","canComment":true}
GMT+8, 2026-4-17 07:53 , Processed in 0.057599 second(s), 23 queries .
