查看: 126|回复: 6
Give me your honest opinion, DD-15 or Paccar? Why? Detroit automatics?
 楼主| 发表于 2019-10-12 00:14:36 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-10-12 01:40:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a DD15 in a 2016 Cascadia. Last quarter, my MPG was 7.76. Not bad on power either. ","replyToPid":0}
发表于 2019-10-12 01:07:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"DD-15 is the best motor out there right now if you want newer emission ","replyToPid":0}
发表于 2019-10-12 00:41:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"right now if you buy New Truck they both good. \ni own a 2012 Paccar . i would buy paccar just because i know it. and has done really good for me. \ni also see owners now with New DD15 doing even better on fuell","replyToPid":0}
发表于 2019-10-12 02:11:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a 2017 Freightliner that I put 275000 miles on it never had an issue with it.","replyToPid":0}
发表于 2019-10-12 02:41:43 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"from what i hear the newer DD15 in a Freightliner  has very few DEF problems"}
发表于 2019-10-12 08:23:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just stay away from the Eaton Fuller Advantage automatic transmission, it thinks it’s saving fuel by shifting itself into neutral anytime you get within 1 mph of your cruising speed 🙄","replyToPid":0}
GMT+8, 2026-4-20 15:03 , Processed in 0.062179 second(s), 24 queries .
